Hi ,
While i am checking the following command in nios 5 i am getting the following error what is the meaning of it?
nb: my fpga is agilex AGFB012R24B2I3E
command is quartus_pgm -c 1 -m jtag -o "ei;examine.fuse;AGFB012R24B2I3E
error is,
Error (18952): Error status: Device does not accept configuration request
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Apr 25 12:31:03 2023
Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 1123 megabytes
Error: Processing ended: Tue Apr 25 12:31:03 2023
Error: Elapsed time: 00:00:22
Error: System process ID: 208
where i can find this error id details?
Greetings and welcome to Intel's forum.
Note that you'll need to specify the command for correct cable number (with c <cable_number>) if you have more than one cable connected to your machine.
You may try to power cycle your board again to see if this issue still appears.
May I also know the Quartus version that you are using with the Agilex FPGA that you have?
Hope to hear on your feedback. Thank you.
Kelly
Any updates or feedback from you end?
Hope to hear from you.
Thank you.
Kelly
Any updates or feedback from you end? Did you managed to find a workaround with the suggestion I provided?
Thank you.
Kelly
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
