I try to instantiate an RS232 UART Intel FPGA IP. and it gives the following error during generation:
Error: rs232_0: The input clock frequency must be known at generation time.
I tried the workarounds available in Intel resources, Both Intel IP catalog or Platform designer does not work. Platform designer has clock source instantiated and clock frequency set properly.
21.2
Have you try the solutions below and see if it helps to solve your error?
https://stackoverflow.com/questions/51346684/quartus-18-ip-error
Thanks a lot. This solution worked for me!
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
I have tried the solution and mentioned it did not work in the original message which was replied with the solution that did not work.
