21602 Discussions
Ethernet RGMII Cyclone V
BIdro
I'm trying to implement an ethernet application in RGMII mode with a NIOS processor in a Cyclone V 5CSEMA5F31 FPGA and Quartus Prime standard Edition 18.1.
I followed a tutorial for Triple-Speed_Ethernet IP and I instantiated the following components in QSYS:
- NIOS II Processor
- CLOCK NIOS
- On-Chip Memory (NIOS - TSE)
- Triple-Speed Ethernet Intel FPGA IP (RGMII)
- Scatter-Gather DMA Controller RX
- Scatter-Gather DMA Controller TX
- On-Chip Memory Intel FPGA IP (descriptor memory for sgdma)
I created the Soc_system with the QSYS and I connected input and output to the respective ports.
This error occurred during the Analysis&Synthesis :
Error (15871): Input port DATAIN of DDIO_IN primitive "soc_system:comp_SoC_System|soc_system_eth_tse_0:eth_tse_0|altera_eth_tse_mac:i_tse_mac|altera_tse_rgmii_module:U_RGMII|altera_tse_rgmii_in1:the_rgmii_in1|altddio_in:altddio_in_component|ddio_in_gsd:auto_generated|ddio_ina[0]" must come from an I/O IBUF or DELAY_CHAIN primitive
I tried to use an ALTIOBUF component for the input bus RGMII_RX(3 downto 0) but it does not work.
Can you help me?
Bryan
BIdro
The solution is to use the Modular Scatter Gather DMA instead of the SGDMA that is obsolete.
EricMunYew_C_Intel
Are your DATAIN directly connected to input pins?
Alternatively, you may refer to below from Rocketboards.
https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
BIdro
Yes, the signal input "eth_tse_0_mac_rgmii_connection_rgmii_in" of the HPS is connected directly to the input ports of the top_level.
I saw the project from Rocketboards but the 2 ethernet peripherals are connected to the HPS.
Instead I need 1 ethernet peripheral to be controlled by NIOS processor in RGMII configuration.
Bryan
EricMunYew_C_Intel
The FPGA supports GMII/MII interface. For RGMII, you will need to add adaptor between GMII/MII to RGMII in FPGA fabric.
BIdro
Hi Eric,
thanks for the reply.
Can you give me an example project or tutorial on this GMII/MII to RGMII adapter?
Bryan Idrobo
EricMunYew_C_Intel
You can find it in c:\intelFPGA\20.1\ip\altera\altera_gmii_to_rgmii_adapter.
EricMunYew_C_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
BIdro
