Hello all.
Does any have an example project for Arria II GX dev board (EP2AGX125 version) that includes all peripherials installed on the board? Thanks.Link Copied
Nobody have it?
--- Quote Start --- Nobody have it? --- Quote End --- I guess not :) Have you downloaded the development kit files from the Altera web site? They typically have a 'golden reference' top-level file that you can use as an initial starting point. They also have example designs showing that each function of the board works. I don't have this particular kit, so cannot comment on what is available. Cheers, Dave
I'm successfully implement a DDR2 and DDR3 memories and some pripherials in one project.
So, at now i try to add TSE_MAC in project. And i have problems. The tse modules connections is typically as other many projects. FPGA project compiles succesfully. Nios project also successfully compiles. But when i load project on board, then NIOS console show it:
Inst & Data Cache Initialized.
Setting up stack and global pointers.
Clearing BSS
Calling alt_main.
Entering alt_main, calling alt_irq_init.
Done alt_irq_init, calling alt_os_init.
Done OS Init, calling alt_sem_create.
Calling alt_sys_init.
and stops the loading. I research that app (ucos) stop at alt_sys_init.c:
void alt_sys_init( void )
ALTERA_AVALON_TIMER_INIT ( HIGH_RES_TIMER, high_res_timer);
ALTERA_AVALON_TIMER_INIT ( SYS_CLK_TIMER, sys_clk_timer);
ALTERA_AVALON_JTAG_UART_INIT ( JTAG_UART, jtag_uart);
ALTERA_AVALON_LCD_16207_INIT ( LCD, lcd);
ALTERA_AVALON_PERFORMANCE_COUNTER_INIT ( PERFORMANCE_COUNTER, performance_counter);
ALTERA_AVALON_SGDMA_INIT ( SGDMA_RX, sgdma_rx);
ALTERA_AVALON_SGDMA_INIT ( SGDMA_TX, sgdma_tx);
ALTERA_AVALON_SYSID_QSYS_INIT ( SYSID, sysid);
TRIPLE_SPEED_ETHERNET_INIT ( TSE_MAC, tse_mac);
at line altera_avalon_timer_init ( sys_clk_timer, sys_clk_timer); So, the sys_clk_timer period sets to 10 ms. It more than needed for most projects. But it can't init the timer....... Reset and Exception vectors are set to Oh-Cnip memory. Why? SOPC system attached: http://www.alteraforum.com/forum/attachment.php?attachmentid=5811&stc=1&d=1335511668
Solved. The problem was in SOPC-system addressing. (28-bit GCC warning in Qsys).
I remap modules addresses, rebuild, recompile and download project to board. It work. But didn't ping now :) Log:
Calling alt_main.
Done alt_sys_init.
Redirecting IO.
Calling C++ constructors.
Calling atexit.
Calling main.
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
497852135
497852135
Your Ethernet MAC address is 00:07:ed:ff:9e:e7
Static IP Address is 192.168.1.2
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x10002000
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY - Checking link...
INFO : PHY - Link not yet established, restart auto-negotiation...
INFO : PHY - Link established
INFO : PHY - Speed = 1000, Duplex = Full
OK, x=17, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.2
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
TX LED on Ethernet port never blink... But RX LED is blink...
I try to use some constraints, modify nios code but no effect.... Confused ((((( Can anybody help?- Mark as New
Nobody solve this problem?
