Programmable Devices
19836 Discussions
Exception in running vector-add on FPGA device on arria10 devcloud
amaltaha
I am trying to run vector-add of fpga_compile example on Intel oneAPI devcloud on hardware FPGA by ./fpga_compile.fpga
I have connected through ssh on MobaXterm and I have specified the node to be s001-n083 which runs fpga and its state was free, but now it shows job-execlusive,  I have walked through the steps one by one and the fpga emulation works normally, I do the steps (in the build file):
1- cmake ..
2- make fpga
then I wait for 2 hours for the queue, then:
3- ./fpga_compile.fpga
and I receive this error:
Running on device: pac_a10 : Intel PAC Platform (pac_ee00000)
Caught a SYCL host exception:
Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
Aborted
amaltaha
using the command
dpcpp -fintelfpga -Xshardware <source_file>.cpp
Solved the problem, make fpga didn't work on any node. probably the problem is in my side.
Thank you!
amaltaha
I get a different error when I try to run it on Stratix 10. which is:
No device of requested type available. Please check https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements.html -1 (CL_DEVICE_NOT_FOUND)
what(): No device of requested type available. Please check https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements.html -1 (CL_DEVICE_NOT_FOUND)
Aborted
aikeu
Hi amaltaha,
I will get back to you when I have info regarding your question.
Aik Eu
aikeu
Hi amaltaha,
I have tried to run the vector add example:
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2B/DenseLinearAlgebra/vector-add
It was ok from my side where I was able to run the whole program following the document without errors.
Sometimes the nodes may encounter issues and is better to retry again or on other nodes.
Aik Eu
amaltaha
using the command
Thank you!
aikeu
Hi amaltaha,
Good to hear that you managed to solve the problem on your side.
I will close this thread for now.
Aik Eu
