Programmable Devices
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
20556 Discussions
External Memif toolkit questions
AustinTatious
I've been pouring through the Intel Quartus Prime Pro Edition User Guide scripting documentation and I found the external memif toolkit. It seems that it has a bunch of the functions I'm looking for, but when I tried typing "help external_memif_toolkit" it says that its only available for use in the qpro_sh and quartus_sh while executing. If I'm writing tcl script that utilizes these functions, how would I go about addressing them?
For example, in the example code for "get_connection_info" I see them using it within the for each loop to get information on each connection, but when I type "get_connection_info -h" I get the error from before about it only being available to qpro_sh and quartus_sh.
AdzimZM_Intel
Hi AustinTatious,
Thank you for submitting your question in Intel Community.
I'm Adzim from Penang Global Application Engineer will assist you in this thread.
For your information, the EMIF Debug Toolkit can only be used with the EMIF IP that has enabled the toolkit port.
The connection might not be working if the port is not provided.
Adzim
AdzimZM_Intel
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
