Hi, i am simulating Signal Integrity Agillex F-Tile FGT .
Until i get the IBIS-AMI is the , i'm using standard IBIS Models downloaded for Agillex from
Can you please guide me for the best fit standard IBIS model for F- Tile that i can use ? or are there separate IBIS models specifically for F-TIle, if so is it included in the IBIS-AMI file ?
currently i using vdiff 1.2V which is the closest to what's on the intel FGT F-tile datasheet .
Avichay
Hi Avichay,
I would suggest you get the IBIS-AMI file for F-tile if it is involved the transceiver part of the device. The standard IBIS model, from what I understand, is only for general purpose I/O.
Aqid
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thanks Aqid
sorry for the late replay.
i managed to get the IBIS AMI agilex_f_gp.ibs files which works.
