Hi!
we are using AGIB027R29A1E2VB FHT for 400GE-4.
when we using (0,1,2,3)-> (0,1,2,3) FPGA design project receive an error :
QSFP112_RX0 -> FHTL12A_RX_CH0
QSFP112_RX1 -> FHTL12A_RX_CH1
QSFP112_RX2 -> FHTL12A_RX_CH2
QSFP112_RX3 -> FHTL12A_RX_CH3
QSFP112_TX0 -> FHTL12A_TX_CH0
QSFP112_TX1 -> FHTL12A_TX_CH1
QSFP112_TX2 -> FHTL12A_TX_CH2
QSFP112_TX3 -> FHTL12A_TX_CH3
but we using Inverse order(0,1,2,3) ->(3,2,1,0) FPGA design project works
QSFP112_RX0 -> FHTL12A_RX_CH3
QSFP112_RX1 -> FHTL12A_RX_CH2
QSFP112_RX2 -> FHTL12A_RX_CH1
QSFP112_RX3 -> FHTL12A_RX_CH0
QSFP112_TX0 -> FHTL12A_TX_CH3
QSFP112_TX1 -> FHTL12A_TX_CH2
QSFP112_TX2 -> FHTL12A_TX_CH1
QSFP112_TX3 -> FHTL12A_TX_CH0
after i check 400GE-4 example. i found example project using Inverse order(0,1,2,3) ->(3,2,1,0).
is that correct?
thanks !
The order of channel naming is reversed order of streams in Ethernet HIP block. For further information, you can refer to link below, section F-tile Architecture, https://www.intel.com/content/www/us/en/docs/programmable/683872/24-1-4-8-0/f-tile-architecture.html
zying
Since no hear any feedback from you, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
