21615 Discussions
F tile Transreceiver Debug Toolkit Communication Problem
emrahener
Hi ,
We are using Interlaken IP with a 12x12.5 configuration on an  AGIB027R31B2E2VAA FPGA . I connect to my board with Ethernet blaster II JTAG cable. I cannot communicate through jtag and get the following error  . I am attaching full log file and a screen shot of the System Console. Can you help me with the problem ?
May 11, 2023 4:11:49 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
SEVERE: An error occurred while running script "ftile_callback_pkg::init_callback
": Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst: missing value to go with key
while executing
"dict get $ArgDict "levnm1""
(procedure "update_gui_tx_eq_param" line 7)
invoked from within
"update_gui_tx_eq_param $i"
(procedure "ftile_callback_pkg::init_callback" line 37)
invoked from within
Full log :
May 11, 2023 4:10:15 PM null
INFO: Reading index <b>C:\intelfpga_pro\22.4\ip\altera\toolkits.ipx</b>
INFO: <b>C:\intelfpga_pro\22.4\ip\altera\toolkits.ipx</b> described 34 plugins, 0 paths, in 0.27 seconds
INFO: <b>C:/intelfpga_pro/22.4/ip/**/toolkits.ipx</b> matched 1 files in 0.27 seconds
May 11, 2023 4:10:15 PM com.altera.debug.core
INFO: Finished initialization
May 11, 2023 4:10:16 PM com.altera.debug.core
WARNING: Could not register IService packet
WARNING: A service named 'packet' is already registered.
May 11, 2023 4:10:18 PM com.altera.debug.core
INFO: Finished discovering JTAG connections
May 11, 2023 4:10:22 PM com.altera.debug.core
INFO: Finished discovering USB connections
INFO: Executing startup script C:\intelfpga_pro\22.4\quartus\..\syscon\scripts\system_console_rc.tcl
WARNING: The script doesn't exist: C:\Users\ENE79354\system_console\system_console_rc.tcl. You can customize System Console by creating one.
May 11, 2023 4:10:25 PM com.altera.debug.core
INFO: Design NestTop.sof is compiled from Quartus Prime Version 22.4.0 Build 94 12/07/2022 SC Pro Edition
INFO: Auto linking AGFB027R24C(.|R2|R0)|..@1#EthernetBlasterII#10.120.8.169 to NestTop.sof
INFO: Created link from (link)/JTAG to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_jtagpins.pins
INFO: Created link from (link)/JTAG/(110:0 v6 #0) to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_0
INFO: Created link from (link)/JTAG/(110:132 v1 #0) to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_1
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_1/phy_0/master to (files)/NestTop.sof/jtag_master.sopcinfo/jtag_master.master
INFO: Created link from (link)/JTAG/(110:132 v1 #1) to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/phy_1 to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t/channel_1 to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_stfabric.h2t_0
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t/alt_sld_fab_0_alt_sld_fab_0_stfabric.h2t_0/master to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_memfabric_transacto.avalon_master
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t/alt_sld_fab_0_alt_sld_fab_0_stfabric.h2t_0/alt_sld_fab_0_alt_sld_fab_0_memfabric_transacto.avalon_master/slave_0 to (files)/NestTop.sof/alt_sld_fab_0.sopcinfo/alt_sld_fab_0_alt_sld_fab_0_memfabric_rom.rom
INFO: Created link from (link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t/alt_sld_fab_0_alt_sld_fab_0_stfabric.h2t_0/alt_sld_fab_0_alt_sld_fab_0_memfabric_transacto.avalon_master/slave_2000000 to (files)/NestTop.sof/NestTop.sld/master_1_0.slave
May 11, 2023 4:10:29 PM com.altera.debug.core
SEVERE: Design with the same hash A436EFECC38F6E8AB19F has been previously loaded at C:\Projects\NEST\Local\QuartusDesigns\BringUpProjects\Interlakenx12TestProject\output_files\NestTop.sof
com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory$DuplicateDesignException: Design with the same hash A436EFECC38F6E8AB19F has been previously loaded at C:\Projects\NEST\Local\QuartusDesigns\BringUpProjects\Interlakenx12TestProject\output_files\NestTop.sof
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory.elaborateQuartusDesign(QuartusDesignFactory.java:424)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory.access$000(QuartusDesignFactory.java:46)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory$1.call(QuartusDesignFactory.java:378)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory$1.call(QuartusDesignFactory.java:375)
at com.altera.systemconsole.internal.core.SystemExecutor.addTaskIfNecessary(SystemExecutor.java:591)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory.create(QuartusDesignFactory.java:375)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusDesignFactory.create(QuartusDesignFactory.java:120)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusProjectLoader.loadProject(QuartusProjectLoader.java:155)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusProjectLoader.loadProject(QuartusProjectLoader.java:138)
at com.altera.systemconsole.designs.internal.quartus_designs.QuartusProjectLoader$1$1.run(QuartusProjectLoader.java:109)
at com.altera.systemconsole.internal.core.SystemExecutor$4.run(SystemExecutor.java:551)
at com.altera.systemconsole.internal.core.SystemExecutor$ComparableTask.run(SystemExecutor.java:151)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
May 11, 2023 4:10:56 PM com.altera.debug.core
INFO: Opening toolkit: Collection_1
May 11, 2023 4:10:57 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
INFO: Loading FGT : with 12 channels
INFO: Finished with CHANNEL CALLBACK
May 11, 2023 4:10:58 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
INFO: Port Number is 50442
May 11, 2023 4:11:00 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
INFO:
##############First Round###############
INFO: Adding 7 + 77
INFO:
############## Providing PySV Server with System Console Server Mode Port ###############
INFO: calling set_servermode_port function
INFO: System console port @ 50415
May 11, 2023 4:11:01 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
INFO: returned message is status true value true message {}
INFO: ==================================================================================================================================================
INFO:
############## Stub Mode Register Device Function Return Value ###############
INFO: calling register_device function
INFO: AVMM2 path is /devices/AGFB027R24C(.|R2|R0)|..@1#EthernetBlasterII#10.120.8.169/(link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_2/alt_sld_fab_0_alt_sld_fab_0_host_link_jtag.h2t/alt_sld_fab_0_alt_sld_fab_0_stfabric.h2t_0/alt_sld_fab_0_alt_sld_fab_0_memfabric_transacto.avalon_master/master_1_0.slave
May 11, 2023 4:11:13 PM com.altera.debug.core
WARNING: This transaction has not completed in 10 seconds.  System Console will keep trying for 50 more seconds.
INFO: Error in receiving data from the server. Please try again.
INFO: Get Parameters button pressed for channel 0
INFO:
############## Getting TX EQ Params from PySV ###############
    while executing
    invoked from within
    invoked from within
May 11, 2023 4:11:49 PM com.altera.debug.core
INFO: Toolkit opened: Collection_1
INFO: tx PRBS Pattern Selection Changed for channel 0
INFO:
############## tx PRBS Pattern Selection ###############
INFO:
Pattern Selected is PRBS31
INFO: rx PRBS Pattern Selection Changed for channel 0
INFO:
############## rx PRBS Pattern Selection ###############
INFO:
May 11, 2023 4:12:04 PM com.altera.debug.core
SEVERE: master_read_32: This transaction did not complete in 60 seconds.  System Console is giving up.
May 11, 2023 4:12:59 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
SEVERE: An error occurred while running script "ftile_callback_pkg::start_button_callback_FGT 0 rx
    while executing
"dict get $returnArgumentsDict "is_active""
    (procedure "get_led_status" line 2)
    invoked from within
"get_led_status $returnArgumentsDict "
    (procedure "ftile_callback_pkg::start_button_callback_FGT" line 5)
    invoked from within
"ftile_callback_pkg::start_button_callback_FGT 0 rx"
May 11, 2023 4:13:42 PM Intel F-Tile Transceiver Toolkit: soft_pcs_nrz.ilk_f_adme_inst
emrahener
The toolkit connection works with Quartus 23.1 but the eye diagram view option is not available with that version.
Kshitij_Intel
Which Quartus version you are using?
Are you able to see the phy in the toolkit explorer?
Also, one important thing please open the system console from Quartus only.
Do not try open the system console directly.
Thank you
Kshitij Goel
emrahener
The log I shared belongs to Quartus 22.4 . I always open the console from quartus. Later I switched to Quartus  23.1 . I have a different problem  described in the following question :
https://community.intel.com/t5/Programmable-Devices/F-Tile-Interlaken-Intel-FPGA-IP-Example-Design-External-Loopback/m-p/1487498/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIVEUzVE5HMzlVVUw4fDE0ODc0OTh8U1VCU0NSSVBUSU9OU3xoSw#M90853
I also tried Pcie DMA IP  with USB Blaster II . I  get a similar error :
Kshitij_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
