21258 Discussions
F-tile "Tile Interface planner" not showing legal locations for PCIe Streaming IP
binupr
New Contributor II
I have two F-tile PCIe Streaming IPs in my design. I opened "Tile Interface Planner" to place these IPs to corresponding banks. But for some reason when I double click to see the legal locations for these nothing shows up. I am using Quartus 23.4. Has anyone seen this issue?
Attaching screenshot along with this.
BPR
RongYuan
In a PCIe example design, you need to assign pin locations to hip rx/tx pins, e.g. hip_serial_tx_n_out0.
A easy way to assign all PCIe including related pins. You could select the top module, e.g. pcie_ed, then choose one of the legal locations shown as attached pcie_interface_planner_all_pins.png. This will complete all pins as shown in pcie_interface_planner_all_pins2.png.
Rong
binupr
New Contributor II
Hi Rong,
What I mentioned was a custom design and not Intel reference design. I already found the issue. Firstly the issue was that the tile planner didn’t show any legal locations. In my design I didn’t want all to assign all lanes in a PCIE IP. But Quartus doesn’t like it. Hence not showing legal allocations. There must be a way not to use all lanes in an IP. Let me know if you have idea on that.
Btw, I have previously generated intel reference design for PCIe. You don’t have to assign hip tx or rx pins. The generated project already has the pins allocated.
BPR
RongYuan
You mean to assign only partial pins of a 1x16 then use it like that?
The PCIe can be downgraded when host has less lanes. Or you can set PCIe IP to 1x8 to use less lanes.
Rong
RongYuan
If no further questions about the interface planner, I'll transit this case to community support. Thanks.
