21489 Discussions
FA Analysis Request for 10M08DAU324I7G 1 PCS
Nazihah
Hi Intel Team,
Currently our production has encountered Failure for this part. This failure has been sent and verified by our CM.
Thus we would like to seek request to support on the FA request.
The details  of the failure are describe as below:
Would need you to assist to help to request for FA from Intel. The detail of the failure and the PO are as below:
PART DESCRIPTION
GRN
DATE CODE
LOTCODE
VENDOR
PART DESCRIPTION
FAILURE MODE (JABIL)
Programmed part U88, 1822-5790 for VXT2
a00001ntcn001001
3720
N/A
ARROW COMPONENTS (M) SDN. BHD.
ABUS failure found no voltage at enable +12p5V_EN from FPGA expected 2.6V measured 0V
PO#: 3012705810
Findings:
ABUS failure found no voltage at enable +12p5V_EN from FPGA expected 2.6V measured 0V.
Suspect component U88 FPGA.
Appreciate if an update on this could be given. Thanks
