21600 Discussions
FPADD/MULT Project NIOSII/F
Here is a project I threw together - seems to produce the right results. Self-extracting archive - 3 pcs.
Steve ...
Subdirectory NIOSII has the project in it to run in the Altera Cyclone 1C20 board.
There is a small bit of code in there too to run in the IDE
Steve ...
you will need all three parts in a directory, run in a command prompt to produce the .zip file
my email address is s.groom@braemac.com.au - if you find any bugs with it.
You can use this freely and modify as you please.
