Form #: 2142792
BEI Part #: HWL52000859-49
Mfg. Part #: 5AGXFB3H4F35I3G
Purchased from Arrow Electronics
Original PO #: WPM285806
Quantity to return: 1
Date code: 2137
Reason for return: rejected by pre-inspection for damage to pad side with lifted mask
Hi RobertOlson,
Good day!
Thank you for contacting Intel FPGA Community Forum.
Can I know the status of this unit either it is fresh raw unit or it is undergone several other test?
Thanks!
Wani
Hi Wani,
This part is a fresh, unused unit. It has not gone through any processing or testing.
The physical damage was found prior to use- damage to pad side with lifted mask
Thank you,
-Rob Olson
507-535-4083
