21335 Discussions
FPGA Board alternative
Purva
Can please suggest an alternative FPGA Board for ACEX 1K series with manufacturer no. EP1K30QC208-3 and also an alternative for FLEX 6000 series with manufacturer part numbers EPF6016QC240-2 and EPF6016ATC144-2?
JohnT_Intel
The device that you are requesting is a very old device and there is no direct alternative to the device. I would recommend you to use our Cyclone series or Max 10 device to replace your device.
Firaseng
Hi John,
Would going to one of these options (Cyclone,Max) requires major changes to the VHDL code.
Firaseng
Hi John,
Thanks for the reply, would going with a Cyclone or Max 10 require mandatory HDL code changes  say for example to the Macros or IP ?
