When I download the.sof file, the download succeeds and the program runs normally.
But by converting.pof files, the download fails at 4%.
so I download CFM0 or UFM ,failed。
When I use the erase function, it can be successful。
I tried a lot of solutions, but they didn't work. I didn't know what was wrong. I was helpless. I hope you can help me solve this problem. Thank you.
Hi there
Please select: Quartus-> File -> Programming file Generator and select MAX 10 and try again~
Hi there,
Is it solved?
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
