21607 Discussions
FPGA Device Selection
sarper
We are trying to project images via VGA to a 1920x1080P LCD monitor from a FPGA device. In parallel, with the same FPGA device, we will be triggering two external devices: industrial camera and pneumatic rotary actuator (both 5V trigger).
However, we could not be sure which Intel FPGA device most cost-effective and compatible is. We would appreciate If you could recommend us a appropriate device. And If possible, some real use case tutorials.
Thank you
Best Regards
JohnT_Intel
Most of the FPGA can implement the solution but it will depend on the functionality that you would like to performed and whether the resources is sufficient for it to fit into the FPGA.
You may refer to https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=&No=1029 which will have the LCD and camera implemented into the board.
