21419 Discussions
FPGA SoCs can't be downloaded using HPS
taojinyong
Refer to the image I uploaded for the error message
We designed an arria10 FPGA, but I can't use Jtag to download it, I don't know what's wrong with the hardware design
taojinyong
To add, I can download sof normally using jtag
mabdrahi
For further debugging, may I know what is the output of the command jtagconfig in your environment?
taojinyong
the message is that
$ jtagconfig
1) USB-Blaster [USB-0]
02E630DD 10AS027E(1|2|3|4)/10AS027H1/..
4BA00477 SOCVHPS
mabdrahi
You may try this command, while i try to replicate your issue
quartus_hp -c 1 -o p --boot -a 0x0 <your_image.bin>
mabdrahi
Any update from your end?
taojinyong
我应该已经解决了这个问题,这可能是DDR内存的电源问题
mabdrahi
 If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
