Altera staff,
I'm new in this forum and I need your help. okay, I'm looking for peroforming the following application: I have a number of devices which communicate to each others through analog signals. what I'm looking for is to use an FPGA bywhich I can interface my devices. To be clear, with theyour product I should be able to do: - routing received signal from one device to another - delaying some signals in specific instance - using a software interface to perform the desired specifcation. - I need at least 10 analog inputs and 3 analog outputs. Specs: -The analog signal input frequency is about 24KHz - the delay range is about 0 to 25µsec - voltage range is +/- 10V for analog inputs and +-5V for the outputs my questions: what's the FPGA type that answers to my applications ? Best Regards.Link Copied
well, no FPGAs have analogue inputs - you will need ADCs for that. And I dont think there are many dev boards with that many analgue inputs. So you'll have to build a custom board.
But from a logic perspective its rather simple. The cheaper cyclones or maybe even a max 5 should be ok.
