Programmable Devices
20689 Discussions
FPGA board selection
I am trying to design a FPGA board to sample received ultrasound signals.
The voltage signal range is around -100~100mV from PZT element.
Could you recommand me a FPGA board with ADC?
The desirable specs are :
Number of Channels : 8~16 channels
ADC : 10~12 bits, larger than 80Mhz sampling rate
FPGA interface to PC : USB 3.0 (2.0 is ok, but larger bandwith is needed to transfer sampled data in real-time)
External trigger enable to initiate sampling.
Transmit beamforming (optional)
