21345 Discussions
FPGA2HPS Bridge Bandwidth Issue
I am trying to use the FPGA2HPS bridge to grab onscreen display frames from the ARM's memory. The FPGA2HPS bridge is set up as 128 bit bus.
I have two VIP Frame Readers:
VFR#1: 1920x1080 (RGBA) with 128 deep FIFO and 64 burst count
VFR#2: 1024x768 (RGBA) with 32 deep FIFO and 16 burst count
The bridge and the VFR avalon busses are clocked at 148.5MHz.
I am getting underflow at the CVO when trying to get frames from the VFR# 1. No issue in getting frames from VFR# 2.
Is the FPGA2HPS bridge bandwidth limited? I was thinking of using the FPGA2SDRAM interface but it seems rather complicated to set up.
Any suggestion on how I can resolve my issue?
Thanks!
Forgot to mention - I'm using Cyclone V SX SoC development board with 1GB memory on the ARM side.
Anyone on the forum able to provide some guidance???
I'd like to know the solution as well.
