This should be trivial, but I've never experienced this issue and I can't seem to solve it! I have a very simple FSM that I use to emulate a switch (given the press of a button). I debounce the button and I detect it's edge -- this is it what drives my state transitions. Now to the issue: even though I have specified the Reset state of my FSM to be the OFF state (1'b0), it is powering up into the ON state (1'b1) and I have to manually hit my reset_n push button to force it into the OFF state. Why is this? I have never had this issue with any other Altera (or Xilinx) FPGAs! (Is it a hardware issue?). I have checked all my signals in SignalTap and the only incorrect signal is "state"... Here is the simple FSM:
module pb_sensor_emulator(
input wire clk,
input wire rst_n,
input wire button_in,
//output wire sensor_out
output reg sensor_out
reg sensor_reg;
/* debounce & detect edge of button */
wire button_edge;
reg button_in_d1;
reg button_db = 1'b0;
// debounce
debouncer deb(
.clk(clk),
.PB(button_in),
.PB_state(button_db)
// detect edge
always @(posedge clk)
begin
button_in_d1<=button_db;
end
assign button_edge = button_db & ~button_in_d1;
/* define states for sensor emulator FSM */
enum logic {OFF = 1'b0, ON = 1'b1} state, nextstate;
/* state transitions */
always_ff @(posedge clk or negedge rst_n)
begin
if (!rst_n)
state <= OFF;
else
state <= nextstate;
end
/* state outputs */
always_comb
begin
/* set defaults */
sensor_out = 1'b0;
/* begin output combinational logic */
case(state)
OFF:
begin
end
ON:
begin
sensor_out = 1'b1;
end
endcase
end
/* next state logic */
always_comb
begin
/* default next-state */
nextstate = OFF;
/* begin next-state combinational logic */
case(state)
OFF:
begin
if(button_edge)
nextstate = ON;
else
nextstate = OFF;
end
ON:
begin
if(button_edge)
nextstate = OFF;
else
nextstate = ON;
end
endcase
end
endmodule
I appreciate your help!
Have you checked this code work as you expected by using test bench? Have you got the correct result after simulation? For this code simulation always showing OFF state for rst_n (Reset) either High or Low. Check screenshot. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
Topic Options
