Hi, I’m using the Case statement inside process that driven by the system clock (“present state” only (no “next state”)). Inside the case I’m using several counters. In Modelsim simulation, the code works well but when I’m burning the code in my CPLD, the code not acting as it should (according to state machine). What could be the problem? I need help… Thanks, Idan
Show the code.
show the code
It's hard to figure out this certain thing.
It's good if you can share the code. And let's see what we can help!- Mark as New
The difference between simulation and real life is that in real life the input signals into your CPLD can be 'very' asynchronous. As a result the registers which make up your state machine may see different values for the changing input and may/will transition into an undefined state or incorrect state. So it is important that you synchronize all external asynchronous inputs (using the recommended 2 register synchroniser)
