21615 Discussions
Fast IO register constraints won't apply
I have a SRAM memory interface in my design and I registered all the signals in a component called mem_ctrl. I set these registers as fast input/output registers in assignment editor. But I got a bounch of warnings like the following:
Warning: Can't pack node "mem_ctrl:COMP_MEM_CTRL|addr[0][0]" and I/O cell a_tap[0]. The node and I/O cell are connected across a Design Partition boundary.
And it takes almost 6.5ns for a signal going from its register to the pin according to the timing analyzer.
Should I put all those registers in the top level to apply fast IO register constraints? Or is there anything else I should pay attention to? (the mem_ctrl component is in the top partition, and I don't understand why the message said the signal needs to across partition boundary).
Your help is very much appreciated.
Hua
Have you applied the constraint to the pin of the top level or a signal lower down the hierarchy?
--- Quote Start ---
--- Quote End ---
Actually, I applied the constraints to both the pin and the register (in the component). Both of them got the warning message.
The constraint should be applied to the register, not to the pin, I think. At least I've been using the constraint succesfully in this way.
Applying to the pin shouldn't create this problem, should it? I will take it out anyway.
--- Quote Start ---
--- Quote End ---
It actually means the opposite. Because of the register packing and fast I/O assigment, they can't cross a partition.
Left click on the warning message and select "Help". Quartus will show a more detailed description of the warning, and will also point you to the relevant Handbook chapter that elaborates about the issue.
I know what you are saying, but what I meant was:
The mem_ctrl module is in the top partition, so the signal doesn't cross any partition boundary. I don't understand why the software think the node and the IO cell are connected across a Design Partition boundary.
Thanks anyway.
--- Quote Start ---
--- Quote End ---
Again, please read the relevant handbook chapter pointed at the warning message help.
There are other reasons that might provoke this warning. e.g, the output enable of the signal can't cross a paritition boundary. Tapping might also restrict register packing.
Thanks vjAlter, I have read those chapters before I came here ...
After tried a few things, it seems that moving those registers from mem_ctrl module to the top level did help... verifying this right now.
--- Quote Start ---
--- Quote End ---
Ok. Sorry about insisting on that.
My point was to make sure you understand all the restriction on I/O register packing when using incremental compilation. And also that, as explained there, the message sometimes is misleading, and might be provoked by other restrictions, not exactly because the node and I/O cell are on different partitions.
None taken, vjAlter.
And yes, moving those registers to the top level did the trick. The register node and the IO buffer are in the same cell now.
It was actually because the signal was used in signal TAP. Removing them from the signal tap (moving those registers to the top level essentially did that) will fix the problem.
