Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Fifo Controller with external memory help needed
Hi All,
I'm new to FPGAs and CPLDs, and I have checked the forum for similar discussions already, so please forgive any repetition here if there is any.
I'm using a MAX II EPM2210F324C3 to design a FIFO controller. I'm planning to use external memory to store data and heading more towards SDRAM over SRAM.
I need to store data 8 bits wide by 251904 bytes deep at least twice. (so double the depth).
I'm trying to use the megawizard to develop a FIFO controller and I can't make a controller deeper than 2048 words.
The question is, how do I make the FIFO deep enough with the functionallity given in the mega wizard?
Adam
