21344 Discussions
Fitter ignores fast i/o assignments.
Why does fitter ignore the sdram fast i/o assignment? The warning is:
Warning (176250): Ignoring invalid fast I/O register assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
Ignored registers are "za_data[*]~reg0" and "m_data[*]". Why?
Quartus can't promote registers to IO registers when:
for outputs: you read the output signal back in your logic
for inputs: you use both registered and unregistered inputs in your logic
