Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Flash Programmer, EPCS Reserved Fields are non-zero
Greetings -
While trying to program a Spansion S25FL032P Flash device on my EP4CE10E22 Cyclone-IV board with the Nios II Flash Programmer, I get the following error messages:
"Looking for EPCS registers at address 0x00011100
Initial values: 9300023.................
Not here: reserved fields are non-zero
No EPCS registers found: tried looking at addresses ..............
Error Code: 8"
Do I need an override file and what should go in it? Any help would be greatly appreciated.
Thank you very much,
Falcon234
Highlighted
Re: Flash Programmer, EPCS Reserved Fields are non-zero
--- Quote Start ---
Greetings -
Error Code: 8"
Falcon234
--- Quote End ---
I was able to solve this problem myself. The Flash Programmer tool seems a bit finicky in that I needed to load my target image into the FPGA using the Quartus-II Programmer tool, within the Flash Programmer tool, immediately before clicking the Start button in the Flash Programmer tool window.
Highlighted
--- Quote Start ---
Greetings -
Error Code: 8"
Falcon234
--- Quote End ---
And btw, I also needed the override file copied to the \bin directory. I added the entry:
[EPCS-010215]# EPCS32N(lead-free)
sector_size = 65536
sector_count = 64
