21602 Discussions
Flash memory size...
so i tested my flash memory using the HAL function (using word mode...)
ret_code = alt_get_flash_info(fd, &regions, &number_of_regions);
the result was printed as:
printf("\nFlash Region Structure:\r\n");
printf("Number of Regions: %d\r\n", number_of_regions);
printf("Offset: %d\r\n", regions->offset);
printf("Region Size: %d\r\n", regions->region_size);
printf("Number of Blocks: %d\r\n", regions->number_of_blocks);
printf("Block Size: %d\r\n\r\n", regions->block_size);
THE OUTPUT IS:
Number of Regions: 2
Offset: 0
Region Size: 65536
Number of Blocks: 8
Block Size: 8192
care some one tell me how this information translates to my flash memory having a 8MB memory???
also what is region size and why my regions is only 2?
8192 * 8 * 65536 * 2 = 8MB (+ spare bytes for ECC).
Why don't you just tell us which flash device you are using?
Jake
hello i am using the de2-70 flash memory...s29gl064n90tf104
hello but 8192 * 8 * 65536 * 2 = 8589934592 <-- byte right?
or am i seriously misunderstood something here....
Here is the datasheet:
http://www.spansion.com/support/datasheets/s29gl-n_01_12_e.pdf
Sorry. I wasn't paying close enough attention. Yeah I'm confused. The HAL driver should be reporting 128 regions of 65536 bytes each.
Jake
The code output only reports the size of the first region, which seems to be 64kbytes, split in 8 blocks of 8kbytes each.
Could you display the size of the second region?
From the datasheet, it seems that this flash memory has a "boot sector" option, and I'm guessing that the first region reported is your boot sector.
hello how could i show the size of the second region??
regions is in fact a table, so this code:printf("Offset: %d\r\n", regions.offset); printf("Region Size: %d\r\n", regions.region_size); printf("Number of Blocks: %d\r\n", regions.number_of_blocks); printf("Block Size: %d\r\n\r\n", regions.block_size);with i between 0 and number_of_regions-1, will give you the information about region i.
oh thanks will try it...
Found this:
Offset: 65536
Region Size: 8323072
Number of Blocks: 127
Block Size: 65536
ok is there any way i could combine these 2 regions???
also when writing, should i offset my first data entry point by that (65536) much ?? (skipping the first region....)
or i could write from offset 0...?
my data length is 65035...
The second region starts right after the first one, so I would say that you can use all the flash as one big region and start at offset 0.
I don't know the specifics about the first "boot sector" region, it could just be a special erasing procedure. There could be more info in the flash datasheet.
I've seen one smaller erase region (boot region) of 32K sectors, followed by a second erase region of 128K sectors on several CFI-compliant flashes.
Cheers,
- slacker
