Dear Experts,
I am currently working on the Agilex F-series Transceiver SOC Development kit, with EMMC as the booting device.
I need guidance on flashing a (.jic) file through HPS Ethernet. If anyone could provide me with the step-by-step process for achieving this, it would be immensely helpful.
Moreover, I am also open to exploring alternative methods to flash the FPGA configuration through HPS Ethernet. If there are any other reliable methods you can suggest, I would be grateful to learn about them as well.
Thank you all in advance for your kind support and assistance.
Raju Satrasala
Hi Raju,
Please use the Intel RSU procedure to do the remote flashing, With RSU, you could send the bitstream through the ethernet and with the RSU application on the board you could do the FPGA Programming.
https://www.rocketboards.org/foswiki/Projects/AgilexHPSRemoteSystemUpdate
Tiwari
Hi @Jeet14 ,
Thanks for the response.
Can you suggest me any another method (or) without using RSU?
Thanks & Regards
Satrasala Raju
We didn't tried other way without RSU.
Now, I will transfer this thread to public forum where you may expect some reply from globally if they have used other other way.
With that, I will close this case by today EOD.
Tiwari
Hi @Jeet14 ,
Suggest me any other methods to flash the jic file through HPS Ethernet.
Thanks & Regards
Satrasala Raju
