21611 Discussions
Floating Point IP ordering sequence
MK_ABQ
New Contributor III
I have a design with multiplication and addition. I have used a multiplier and adder "Floating Point Function IP". I am wondering how do I create a  logic so that multiplier IP is used first, and then the result is fed  to adder IP. Any suggestions?
MK
ZiYing_Intel
Hi MK,
Thanks for submitting the issue.
Please do allow me have some time to look into the issue and I will get back to you with findings.
Zi Ying
ZiYing_Intel
Hi MK,
I would suggest you change the function name from Multiply to Multiply-Add. Multiply-Add can performs two input multiplication followed by addition.
Zi Ying
ZiYing_Intel
Since I have addressed your question and no hear any feedback from you, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue.
Zi Ying
