hello!
I use dsp builder create a DDS project. But I use quartus II compile it, I get a critical warning(require time is 100M , the actual time is 77.7M ). How can do solve the problem? thank you very much!Link Copied
I would say you need to pipeline your design better to meet the timing requirements. Use TimeQuest to analyze where your design is failing and add some register in this path.
