21335 Discussions
Generating PS2 Interrupts
I am trying to write a simple interrupt service routine for interrupts from a PS2 mouse on a DE2 board, but the following assembly code never executes the ISR. I am quite certain that the code is correct but I can't figure out why I am not catching any interrupts. Any advice is appreciated.
Regards.
.text .global _start _start: .equ ADDR_PS2, 0x10000100 .equ ADDR_PS2_CONTROL, 0x10000104 /* Enable interrupts for PS2 by writing to bit 0 of the control register */ movia r2, ADDR_PS2_CONTROL movia r3, 0x1 stw r3, (r2) /* Set the PIE bit */ movia r2, 0x1 wrctl ctl0, r2 /* Configure ienable: PS2 IRQ = 7 */ movia r2, 0x80 wrctl ienable, r2 MAIN: br MAIN .section .exceptions, "ax" ISR: subi sp, sp, 56 stw r14, 52(sp) stw r13, 48(sp) stw r12, 44(sp) stw r11, 40(sp) stw r10, 36(sp) stw r9, 32(sp) stw r8, 28(sp) stw r7, 24(sp) stw r6, 20(sp) stw r5, 16(sp) stw r4, 12(sp) stw r3, 8(sp) stw r2, 4(sp) stw r1, 0(sp) rdctl r2, ipending movia r3, 0x80 and r2, r2, r3 bne r0, r2, PS2_HANDLER br ISR_RETURN PS2_HANDLER: /* Acknowledge the interrupt */ movia r2, ADDR_PS2 ldb r3, (r2) /* Turn on the green LEDs */ .equ ADDR_GREEN_LEDS, 0x10000010 movia r2, ADDR_GREEN_LEDS movi r3, 0xff stwio r3, (r2) /* Wait for a moment */ movia r2, 25000000 PS2_WAIT: subi r2, r2, 1 bne r0, r2, PS2_WAIT /* Turn off the green LEDs */ movia r2, ADDR_GREEN_LEDS movi r3, 0x0 stwio r3, (r2) br ISR_RETURN ISR_RETURN: ldw r14, 52(sp) ldw r13, 48(sp) ldw r12, 44(sp) ldw r11, 40(sp) ldw r10, 36(sp) ldw r9, 32(sp) ldw r8, 28(sp) ldw r7, 24(sp) ldw r6, 20(sp) ldw r5, 16(sp) ldw r4, 12(sp) ldw r3, 8(sp) ldw r2, 4(sp) ldw r1, 0(sp) addi sp, sp, 56 subi ea, ea, 4 eret
