21611 Discussions
Generating an Agilex per pin RLC IBIS (.ibs) file
sumanth1
I'm trying to produce an ibis file for my FPGA design using the method outlined in:
Generating an Agilex per pin RLC IBIS (.ibs) file (intel.com)
I require package-specific RLC data for the AGFB012R24B2I3E per pin package. Not the one provided in below link. as i'm geeting error.
IBIS Models for Intel Field Programmable Gate Array Devices | Intel
AqidAyman_Intel
Thank you for reaching out Intel FPGA Community.
I have attached the requested file via email. Kindly check your inbox.
Aqid
khagesh
Hi Aqid,
Thanks for your support. We tried to generate IBIS model provided by your attachment for our package using TCL script by following below link. But we get Error- “can’t Read package R_TYPE variable missing” attaching image too.
https://community.intel.com/t5/FPGA-Wiki/Generating-an-Agilex-per-pin-RLC-IBIS-ibs-file/ta-p/1342589
AqidAyman_Intel
I have emailed you another file.
Can you check it?
Aqid
AqidAyman_Intel
Do you have any updates? Did you manage to overcome the error seen previously with the new file?
There is a blog from CadEnhance shares the steps you can try to build the IBIS Model for Intel Agilex. You can see below link, perhaps maybe it can also help you. This is just a suggestion, not a solution from me.
https://www.cadenhance.com/blog/how-can-i-build-an-ibis-model-for-the-new-intel-agilex-fpga-design
Please let me know if you still encountered the error.
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
