20400 Discussions
Getting error on mSGDMA IP
ap_mercy
Im trying to follow the example in this page with 2 mSGDMAs: https://blog.reds.ch/?p=835
when i run synthesis I get the below error:
EBERLAZARE_I_Intel
I see that you are using Stratix 10 Device, you can refer to below design instead:
https://rocketboards.org/foswiki/Projects/Stratix10SoCDesignExampleFor10GbeWithIEEE1588PTPCapability212
ap_mercy
Hello, thanks for your response. This example seems like an overkill for what what I'm trying to accomplish. I tried the example from https://blog.reds.ch/?p=835  on the latest quartus pro and still get the same error with mSGDMA IP.  Is there an example that demonstrates only uses mSGDMA similar to what's on that (https://blog.reds.ch/?p=835) website?
EBERLAZARE_I_Intel
For Stratix 10 there are non simple example design, however it is quite straightforward to port below design of the Arria 10 to the Stratix 10 below:
https://fpgacloud.intel.com/devstore/platform/17.1.0/Pro/arria-10-nios-ii-simple-socket-server-design-example/
ap_mercy
