20398 Discussions
Ground pins for a 5M40ZE64C4
KBowe2
Trying to use a 5M40ZE64C4 and the documentation does not show any ground pins.. any help?
MBenca
Hello KBowe2,
there is the following note in the pin information document for Intel/Altera MAX V device family (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-v/5m40z.pdf):
The E64 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane on your PCB. This exposed pad is used for electrical connectivity and not for thermal purposes.
Martin
KBowe2
Thanks..That is should be in Bold print.. I think I checked that page several times and never saw that..
NurAiman_M_Intel
Hi Ken,
I have seen your case 6 days ago and i believe Martin's answer have address your query. I will now proceed to close this case. Do not hesitate to open a new case if you have any queries.
Thank you.
Aiman
