21600 Discussions
HDMI IP Design Example -> i2cslave_to_avlmm_bridge.v -> waveforms
amildm
Valued Contributor I
Hi All,
In the HDMI Intel® Arria 10 FPGA IP Design Example,  there is a module named i2cslave_to_avlmm_bridge.v .
Is this IP? Where can I see its documentation?
Where can I see waveforms related to the module?
Thank you!
ZH_Intel
Hi amildm,
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi amildm,
Thank you for your patience.
The mentioned file, i2cslave_to_avlmm_bridge.v, is part of file generated for HDMI design example to work.
You may locate the file in the HDMI example design folder, provided you enable the "include i2c Master/slave" option in platform designer.
(Directory: hdmi_0_example_design\rtl\hdmi_rx\hdmi_rx\altera_hdmi_1961\synth\hdmi_rx)
As for documentation, you may refer to Intel Embedded Peripherals IP User Guide, Chapter 15 & 16 for more information.
(Link: Intel Embedded Peripherals IP User Guide )
Hope this helps!
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi amildm,
Thank you.
ZulsyafiqH_Intel
