Programmable Devices
20764 Discussions
Hang system when access to BAR0, SV HARD IP CORE AVMM DMA
abeli1
Good afternoon colleagues
Help me to understand
1) Launched PCIE HARD IP 256-bit AVMM DMA
2) Trying to run the dma controller
3) I am writing data in a bar0 from Linux
4) As soon as I call the iowrite32 35 times, the system freezes. At the same time, after each entry, I try to read the data and get 0xFFFFFF
Please tell me what could be the problem?
c++ driver code
init_chrdev(..) pci_enable_device(..) request_mem_region( pci_resource_start(_device, 0), pci_resource_len(_device, 0), ALTERA_DMA_DRIVER_NAME ) pci_iomap (...) pci_enable_msi(...) iowrite32 ( cpu_to_le32(tmp_rand), (u32 *)(_dev_data_ptr->bar[0]) + i );
Also, if my driver is loaded, I need to contact any utility to pci (lspci for example), the system immediately hangs
Under windows the same
Thank you in advance
SengKok_L_Intel
​Hi,
Are you referring to any example design from Intel PSG? Or the driver and PCIe design is created by yourself?
Regards -SK
