Good afternoon colleagues
Help me to understand
1) Launched PCIE HARD IP 256-bit AVMM DMA
2) Trying to run the dma controller
3) I am writing data in a bar0 from Linux
4) As soon as I call the iowrite32 35 times, the system freezes. At the same time, after each entry, I try to read the data and get 0xFFFFFF
Please tell me what could be the problem?
c++ driver code
init_chrdev(..)
pci_enable_device(..)
request_mem_region(
pci_resource_start(_device, 0),
pci_resource_len(_device, 0),
ALTERA_DMA_DRIVER_NAME
pci_iomap (...)
pci_enable_msi(...)
iowrite32 (
cpu_to_le32(tmp_rand),
(u32 *)(_dev_data_ptr->bar[0]) + i
Also, if my driver is loaded, I need to contact any utility to pci (lspci for example), the system immediately hangs
Under windows the same
Thank you in advance
Are you referring to any example design from Intel PSG? Or the driver and PCIe design is created by yourself?
Regards -SK
Topic Options
