21611 Discussions
Help!!! .pof file
I'm a newbies of Altera software. May I know how do I open .pof file any software can use? Thanks. :)
The pof file is used by the Programmer, accessible directly inside the Quartus II environment.
Have you installed Quartus II?
--- Quote Start ---
--- Quote End ---
Yup, I have Quartus II. Can I view the contents with Quartus II? Is .pof file is a program source code?
I don't think Altera lets you view *.pof and *.sof files. You can only use them to program your FPGA using the Quartus II programmer...
--- Quote Start ---
--- Quote End ---
Do you mean .pof is some sort like machine code (.hex)? Which Altera file extension can view the source code?
What I am saying is that, I don't think Altera wants you to be able to read pof files...
Why do you need to read them anyways??
The pof file is the binary file for programming the configuration memory. You could view it in any binary file viewer f you like but it won't tell you much - it's just a load of binary stuff.
Source code could be .vhd or .v or .bdf or .tdf or probably many others depending on the language.
