Hi all,
as part of my finalproject in my electronic engineering studys, i am supposed to have a NIOS2with multymaster, multyslave I2C components. On the SPOC i sawthere is no such interface. Does anyone have a verilog/vhdl code for such aninterface? Can someone give me help with what direction should i carry on myresearc regarding this issue?Link Copied
You can find it from alterawiki.
Thanks for your help. I saw this page but to my best understanding, it works with wishbone, and I think i need for the NIOS Avalon.
Am I right? if i use a code from opencore do i need to publish my code?- Mark as New
does this reference design not fit your needs? http://www.altera.com/support/refdesigns/sys-sol/indust_mil/ref-i2c.html Greets- Mark as New
Thanks. Do i get there the design verilog/vhdl code?
I did not quite understand what does this I2C Controller Reference Design mean. Is it a board? Is it a SW tool? Can I play around with the code? Many thanks in advance.- Mark as New
a reference design is a vhdl/verilog design you can use in your application for free. Greets- Mark as New
--- Quote Start --- Thanks for your help. I saw this page but to my best understanding, it works with wishbone, and I think i need for the NIOS Avalon. Am I right? if i use a code from opencore do i need to publish my code? --- Quote End --- Someone has ported the opencores i2c masteer to Avalon bus.You can use it directely. http://www.alterawiki.com/wiki/i2c_(opencores)
