20704 Discussions
Hi, i am using " arria10.ibs" model for 10AX027E3F27E2SG part, while doing simulation i have one issue that showing like " pin AC13 of component ARRIA 10 has no model in file"
KTATA1
Hi, i am using " arria10.ibs" model for 10AX027E3F27E2SG part, while doing simulation i have one issue that showing like " pin AC13 of component ARRIA 10 has no model in file" . For this pin i have connected 100Mhz clock signal. please tell me why this error occured. Sim tool is hyplynk 2.3v
YuanLi_S_Intel
Hi KTATA1,
I am just curious, how do you get a IBIS model with pin AC13? Are you generating the IBIS from Quartus?
For IBIS model obtained at link below, you will only need to choose the I/O Standard and change the RLC based on the device part number in order to perform simulation.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/board-layout-test/ibis/ibs-ibis_index.html
YL
