I'm using Quartus Prime Lite 16.0. I need to add the ALTPLL megafunction to my bdf. I cannot find the Insert Symbol option under Edit Menu, which usually led to the Plug In manager MegaWizard.
I use Quartus12, and I can access it from the tools menu.
It is called "IP catalog", you can find in tools menu
Hi guys, Has this problem been solved?
I have the same problem with Quartus Prime Lite 16.0 Thanks- Mark as New
Thank daibylovebaby, IP catalog is really helpful
Topic Options
