Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
How do I open the Plug-in manager in Quartus prime 16.0 ?
I'm using Quartus Prime Lite 16.0. I need to add the ALTPLL megafunction to my bdf. I cannot find the Insert Symbol option under Edit Menu, which usually led to the Plug In manager MegaWizard.
Highlighted
I use Quartus12, and I can access it from the tools menu.
Highlighted
It is called "IP catalog", you can find in tools menu
Highlighted
Hi guys, Has this problem been solved?
I have the same problem with Quartus Prime Lite 16.0
Highlighted
Thank daibylovebaby, IP catalog is really helpful
