21607 Discussions
How should I connect clk and pll_refclk0 in RapidIO IP Core of Arria10?
SYiwe
Hi all,
In my design I instantiate a RapidIO core and a ATX PLL core, and the device is Arria10.
clk is the reference clock for RX CDR block in transceiver,
pll_refclk0 is the input clock of ATX PLL,
clk and pll_refclk0 should be driven from the same clock source.
Is clk a differential signal?
Should I connect both of them to the same dedicated reference clock pin?
Thanks, regards.
SreekumarR_G_Intel
Hello , I would say connect to the external clock input to the global clock pin and add the clock constraint. Make sure it is connected to the non-inverted (name_p) clock if it is single ended clock input and inverted pin can be left open. Thank you , Regards, Sree
