20253 Discussions
How to add an external flsha to Max10 series?
PID
Hi, I'm using the Max10 series PFGA(10M08SCU169) to make a control board, but I don't know whether the internal flash is enough.
Can you give me some solutions or advice on how to add  an external flash to my FPGA?
YuanLi_S_Intel
You may add external QSPI flash. You may refer to the design example available at this document
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf#page=5
Thank You
PID
Thanks for your reply. I will learn this file to find the solution.
YuanLi_S_Intel
I am glad it helps. Let me know if you need anything
