20242 Discussions
How to constrain a ADC input to a narrow delay window Arria 10
KCMurphy
New Contributor II
I have an external ADC which I need to sample with an internally generated clock.  Reasons.  The ADC data conversion is driven by a clock I output, and I would like to sample it with a derived clock at some phase angle.
To do this reliably, I need to be able to constrain both the output clock and the input data paths to some known delay window.  At first blush it looks like set_max_delay and set_min_delay would do the trick, but those directives seem to be aimed at setup and hold time respectively, which is not what I want.  I simply want to control the routing so that the delay is known (and repeatable).
I can set skew, which is nice, but I still need to constrain the delay time.
KCMurphy
New Contributor II
Never mind.  Did some more reading and set up a proper input delay
tventing
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
