Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
How to create filesystem for linux4 with nios2
I get kernel panic likely because I don't have a filesystem. I don't know how I should enable it. I see in menuconfig there are option for the RAM filesystem and I tried setting that both to explicit files and the directory of the buildroot images. Nothing worked. Can you help me?
Code:
Linux version 4.9.0-00104-g84d4f8a-dirty (developer@1604) (gcc version 6.2.0 (Sourcery CodeBench Lite 2016.11-32) ) #48 Fri Apr 7 22:39:28 CEST 2017
bootconsole [early0] enabled
early_console initialized at 0xe8001440
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c084e52c, node_mem_map c0883b80
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32768 pages, LIFO batch:7
��pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: debug console=ttyAL0,115200
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Sorting __ex_table...
Memory: 121196K/131072K available (2233K kernel code, 66K rwdata, 352K rodata, 5852K init, 197K bss, 9876K reserved, 0K cma-reserved)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:64 nr_irqs:64 0
clocksource: nios2-clksrc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 38225208935 ns
Console: colour dummy device 80x25
Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=50000)
pid_max: default: 32768 minimum: 301
�����������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
cpu cpu0: Error -2 creating of_node link
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
random: fast init done
clocksource: Switched to clocksource nios2-clksrc
random: crng init done
futex hash table entries: 256 (order: -1, 3072 bytes)
workingset: timestamp_bits=30 max_order=15 bucket_order=0
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
8001440.serial: ttyJ0 at MMIO 0x8001440 (irq = 2, base_baud = 0) is a Altera JTAG UART
mousedev: PS/2 mouse device common for all mice
Warning: unable to open an initial console.
Failed to create /dev/root: -2
VFS: Cannot open root device "(null)" or unknown-block(0,0): error -2
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Could you please help me get unstuck? I'm stuck where Linux boots. I built latest version of Linux from Altera for my Altera DE2-115 FPGA. It won't boot properly because of something with the file system. Maybe you know what I should do? I suppose it is some option in make menuconfig but I don't know what do to.
Linux version 4.9.0-00104-g84d4f8a-dirty (developer@1604) (gcc version 6.2.0 (Sourcery CodeBench Lite 2016.11-32) )# 28 Wed Apr 5 04:23:07 CEST 2017 bootconsole enabled early_console initialized at 0xe8001440 On node 0 totalpages: 32768 free_area_init_node: node 0, pgdat c022166c, node_mem_map c0254b80 Normal zone: 256 pages used for memmap Normal zone: 0 pages reserved Normal zone: 32768 pages, LIFO batch:7 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: debug console=ttyAL0,115200 PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Sorting __ex_table... Memory: 127528K/131072K available (1750K kernel code, 66K rwdata, 284K rodata, 76K init, 191K bss, 3544K reserved, 0K cma-reserved) SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:64 nr_irqs:64 0 clocksource: nios2-clksrc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 38225208935 ns Console: colour dummy device 80x25 Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=50000) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) cpu cpu0: Error -2 creating of_node link clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns random: fast init done clocksource: Switched to clocksource nios2-clksrc futex hash table entries: 256 (order: -1, 3072 bytes) workingset: timestamp_bits=30 max_order=15 bucket_order=0 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) 8001440.serial: ttyJ0 at MMIO 0x8001440 (irq = 2, base_baud = 0) is a Altera JTAG UART mousedev: PS/2 mouse device common for all mice Warning: unable to open an initial console. List of all partitions: No filesystem could mount root, tried: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) random: crng init done
https://www.alteraforum.com/forum/attachment.php?attachmentid=13503 https://www.alteraforum.com/forum/attachment.php?attachmentid=13504
After deselecting Nios II DIV and configuring some more options, I get the login prompt and a shell via JTAG UART.
But why do I get junk on the screen? It looks like this Welcome to Nios II nios2 login: root ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ login: root login on 'ttyJ0' #
The whole boot sequence is the following
Welcome to Nios IILinux version 4.9.0-00104-g84d4f8a-dirty (developer@1604) (gcc version 6.2.0 (Sourcery CodeBench Lite 2016.11-32) )# 64 Mon Apr 10 22:33:34 CEST 2017 bootconsole enabled early_console initialized at 0xe8001440 Warning: icache size configuration mismatch (0x8000 vs 0x1000) of CONFIG_NIOS2_ICACHE_SIZE vs device tree icache-size Warning: dcache size configuration mismatch (0x8000 vs 0x800) of CONFIG_NIOS2_DCACHE_SIZE vs device tree dcache-size On node 0 totalpages: 32768 ��free_area_init_node: node 0, pgdat c042824c, node_mem_map c043fb80 Normal zone: 256 pages used for memmap Normal zone: 0 pages reserved Normal zone: 32768 pages, LIFO batch:7 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Sorting __ex_table... ��Memory: 125564K/131072K available (1878K kernel code, 57K rwdata, 440K rodata, 1876K init, 79K bss, 5508K reserved, 0K cma-reserved) NR_IRQS:64 nr_irqs:64 0 clocksource: nios2-clksrc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 38225208935 ns Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=50000) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) devtmpfs: initialized cpu cpu0: Error -2 creating of_node link clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns random: fast init done clocksource: Switched to clocksource nios2-clksrc futex hash table entries: 256 (order: -1, 3072 bytes) workingset: timestamp_bits=30 max_order=15 bucket_order=0 jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) 8001400.serial: ttyAL0 at MMIO 0x8001400 (irq = 3, base_baud = 3125000) is a Altera UART 8001440.serial: ttyJ0 at MMIO 0x8001440 (irq = 2, base_baud = 0) is a Altera JTAG UART console enabled console enabled bootconsole disabled bootconsole disabled loop: module loaded mousedev: PS/2 mouse device common for all mice Freeing unused kernel memory: 1876K (c01d7000 - c03ac000) This architecture does not have kernel memory protection. ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@random: crng init done ���������...��^@^@^@...^@^@^@^@^@^@^@OK Initializing random number generator... ���...�����������������������������������������������������������������^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@done. ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^��...���������������@...@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Starting network: ip: socket: Function not implemented ip: socket: Function not implemented FAIL Welcome to Nios II nios2 login: root ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ login: root login on 'ttyJ0' #
https://www.alteraforum.com/forum/attachment.php?attachmentid=13509 https://www.alteraforum.com/forum/attachment.php?attachmentid=13510 https://www.alteraforum.com/forum/attachment.php?attachmentid=13511 https://www.alteraforum.com/forum/attachment.php?attachmentid=13512
First way:
Run portmap before mount command:
portmap &
mkdir /mnt/nfs
mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.1.2:/home/nios2 /mnt/nfs ( eg, server ip 192.168.1.2)
Second way:
add fstab in [/nios2-linux]/uClinux-dist/vendors/Altera/nios2/ and edit the Makefile to have a copy in /etc in kernel image.
Content of fstab:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
192.168.1.2:/home/nios2 /mnt/nfs nfs rsize=1024,wsize=1024,noauto,nolock 0 0
Now you can access the mount point with:
portmap &
mkdir /mnt/nfs
mount /mnt/nfs
Or you could add these lines in [/nios2-linux]/uClinux-dist/vendors/Altera/nios2/rc to mount it automatically at startup
Then Nios II client can access files on /home/nios2 of server through /mnt/nfs mount point.
The mount command in sash does not support nfs mount.
You may use the busybox "mount", and enable the "nfs support" in busybox "mount". You may enable "cp" in busybox, which can support recursive copy. You need to clean up busybox, with "make -C user/busybox clean" , "make" "make romfs" and "make linux image" to rebuild kernel image.
pes university bangalore fee structure (http://www.admissionpro.in/pes-university-bangalore-fee-structure-nri-direct-management-quota.html
reva institute of technology and management bangalore management quota (http://www.admissionpro.in/reva-institute-of-technology-and-management-bangalore-fee-structure-nri-d...)
