21489 Discussions
How to debug the PS program through USB Blaster II in CycloneV SOC?
frotho
    I'm just started to the CycloneV SOC 5CSEA5 FPGA, I know how to debug the PL program through USB Blaster and watch signal in SignalTap, but how can I use USB Blaster to debug the PS program in DS-5?
   ps: The SOC starts to load the micro OS system, and then executes the application in the PS. I want to debug the application in the DS-5 through the USB Blaster.
Thanks!
NurAiman_M_Intel
Thank you for contacting Intel community.
By PS, do you mean Passive Serial? Kindly refer to Cyclone V handbook below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
Aiman
frotho
Hi Aiman,
    Thanks for your kind reply, I had viewed the cv_5v2.pdf document, but I did not find the relevant content.
    By PS, I mean the HPS in the Cyclone V SOC, I want to debug the ARM program with USB Blaster II in the DS-5.
frotho
Hi Aiman,
NurAiman_M_Intel
Our team will continue to support you through case 05299527 as it was a duplicate case. I will continue to close this one.
Aiman
frotho
Hi Aiman,
    Thank you all for your help.
    How can I get the case 05299527, and Is there any detailed documentation on this case?
Best Regards
Frotho
