Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
How to ignore Latches for Timing analysis
Hi ,
I have latches (as combinational loops) which must be used in my design. These latches acts as start/end point for timing analysis.
So my design is not getting properly optimized.
Is there any way, i can ignore these latches from timing analysis & for synthesis/Fitter optimizations.
I have tried False path/ disable timing constraints and it didn't work. Also tried switch -no_latch for timing but its not useful.
NKD
Hello ,
Can I guide tool to ignore latches as sequential elements. Either in synthesis or Fitter stage.
NKD
