19837 Discussions
How to instanite a spi interface
I have a DE1-SoC board. I'd like to learn how to instantiate a SPI interface on the FPGA. The plan is to connect connect it to an MCU with jumper wires via the exposed GPIO on the DE1-SoC board.
I was wondering if somebody could point me towards a tutorial to create a spi interface on the fpga?
i'm trying to do the same now. Did you understand how to manage this? I have problems with Pin Assignment and C Code to be load on DE1-SOC. I've implement SPI on the FPGA as Slave and you ? Which kind of MCU are you using ? Are you using it as Master in the communication ?
There is a IP block in Qsys with SPI interface. I've never used it
May be useful for you.
