21602 Discussions
How to program a EPCQA flash device with MAX10?
GBusl
Ola,
I am using NIOS and want to boot from EPCQA flash. Can you please help to teach me how to do so?
Ahmed_H_Intel1
with the MAX 10, I've created before and example of parallel flash loader to program the flash, but in your case you are using the EPCQA device which is a serial active and isn't compatible with the parallel flash loader. You have to use the serial flash loader to make the FPGA as a bridge between the JTAG and the flash.
Please let me know if I got your point. If not please provide more info about the issue.
Ahmed_H_Intel1
GBusl
Thanks, you already solved my problem here and in another thread.
I really appreciate your answer @AhmedH_Intel​
